- Joined
- Jul 17, 2007
- Posts
- 499
- Reaction score
- 2
Not sure which section to put this in, as both the 4.0 and 4.6 share this transmission minus the input shaft and a few other goodies, but after some research, I think my issue is cross platform, so I'll post it here.
Some of you may be aware, that my last 3 or 4 trips to the track have been plagued with my 3-4 shift hanging, and it seems to get worse with either raised power levels, or heat. Will get back to that. But essentially this is what I experience on the track and street, at boost levels from 13psi to 17psi, and juice (have not had a chance to test it on 20psi+, but don't think its needed)...
I am prepared for the fact that my transmission may be starting to fail (after 2 race seasons, NA+Juice, Turbo at 8, 11, 13, 15, & 17psi + juice) as I have really beat on it a good bit. However, in talking with other S197 owners, I have found others that have this issue, with different setups.
So far, I have found the following with this problem...
But before doing that, I wanted to see if anyone else has run into this issue. My auto transmission is nearly stock, minus a reworked stall (about 500k over stock) and a PA oil pan (extra 4 qts) and I'm running Amsoil synthetic oil in my transmission.
Anyone else run into this issue? Its significantly impacting my ET's and consistency of the car (ie bracket racing). Could it be the fact that the transmission is from the first batch of S197's? Or just the transmission is broken in a fair bit from racing?
On the street, its 100%, no slippage of gears. So it makes me wonder if its really a sign of it failing. Of course I may know more once Mike studies the logs and/or cracks open the transmission. But the later will not happen till after race season.
Sorry for the long winded post, comments and feedback are much appreciated.
- From a dead stop, do a hard launch
- 1-2, 2-3 shift is rock solid, no delay, car shifts hard
- 3-4 shift....revs high....holds and then shifts
- (1) 05 GT Owner, bolt ons
- (1) 06 V6 Owner, pro-charged, cammed (easily over 400rwhp on a DJ)
