$999 CNC Head Sale!
Livernois Motorsports
Dearborn Heights, MI
Save on CNC Heads! Send us your heads for CNC, valve, and assembly work for only $999!
With our highly experienced cylinder head team, we will be able to test and machine your cores to perfection! From Ford to GM, we can CNC them all!
Give us a call or email us for more details!
(313) 561-5500
[email protected]
05stroker
Never enough power guy!
Bullard Tx.
Does that include include unshrouding the intake valves as well or is that an additional charge?
RazorbackMustang
MT82 Lover
Springdale, AR
i believe a company makes bearing inserts that can repair scored cam journal towers
I'm sure they can be repaired. But I'm equally sure it would very expensive to get 20 cam journals fixed. :( They were on a spare engine I bought to build but ending up parting out because it was more damaged than I realized. I made money on the deal so no biggie, but my initial plan was to build it. This would have been a nice addition.
o2sys
NY/NJ
So can I send you my stock heads to be CNC'd and send you new cams and springs to be installed at the same time for $999?
BadPiggy
Hooligan Ahole
Knoxville, TN
if I supply the oversize valves, what is the additional fee to install/cut seats to accommodate these valves? Also, are bronze guides included in the $999 price?
My oversize valves are new Manley's, 1mm oversize, and the correct part for the 3V head.
Also, I'll be installing a Comp Cam 127550 which will need a heavier spring. Price for spring upgrade?
