about to order wheels... should i or no?
KoolerSL2
Serve and Protect
Jackson, TN
after looking ive decided to go ahead and order 20's.
heres the ones ive reserved.
http://www.tirerack.com/wheels/Whee...true&filterBrand=All&filterNew=All&sort=Price
they are 20x10 all around with a 45mm offset.
main question is will these sit well in the fenderwells? and fill them out width wise?
or will i probally have to put some spacers in the back to fill em out?
and they are gonna run $282 shipped to my door.
AJ
US Muscle, AUS Hustle....
LuckyH
,location,location
They should fit fine. I'm running a +40 offset on 18x10's all around and they sit flush the fenders. So with a higher offset they should be fine and sit just inside the fender. Figure there's a 5mm difference between mine and yours, and at worst you might want to run a 2mm spacer if your really anal.
Mine for reference. Remember, yours will sit in 5mm more, hardly noticeable at all.
With the camber, only the bottom of the wheel barely comes outside the fender.
Redfire_WNL
THE BEAST UNLEASHED!
TAMPA, FL
Um $45 I think it is worth it to buy them and see what they look like and then If you dont like them sell them for double a wheel at $90.
stang8psi
Slower,Lower Delaware
they will fit! I have the same wheels but the silver ones. the 20x10's do have a lip to them also, you will be pleasantly happy.
kevinatfms
EX-ford tech(6 years)
MD
buy my 18x9.5 steeda pentars!!!!
they sit nice and aggresive...
