***Edit: Consolidated everything to this first post.
Intermittently, while accelerating I'm getting a shudder throughout the car at the same time it's backfiring some and the car doesn't have full acceleration. The boost gauge goes crazy with the needle jumping all over the place as does the AFR. Goes from Rich to Lean...back and forth. If I let off the gas and wait a few seconds, it all goes away and the car runs like a champ. Then it does it again after awhile. Driving without putting the car under load, i.e., staying out of boost is fine most of the time, it's when accelerating into boost...but not every single time. I can also go WOT to 15psi with zero issues.
I previously had a vac leak which I fixed by getting a new vac actuator. There's no other leak that I can find. AFR, idle, fuel pressure, fuel pump DC, water temp, oil pressure, IAT, vac (22) and max boost (15) are all fine.
Also, I got a hold of Saleen tech and although they could have sold me a bypass kit, they don' think that's the problem. Just for a test, they suggested to back out the actuator set screw one turn just in-case the bypass wasn't fully closing. Not only that, but I put the 3.4 pulley on dropping from 15psi to 8psi to reduce the pressure and neither change made a difference.
So far I've tried:
New HT0 plugs at .30
New Coil Packs
New O2s
Different CAI, MAF Housing/MAF
2 tunes from two different tuners (data logged)
About 5-7 test tunes (thanks lito) and 10-15 datalogs concluding that it's not a tune issue
Compression test O.K
Swapped Injectors
Snif test of coolant tank and came out positive for hydrocarbons.
Different PCM and test tune (thanks again lito) (need to figure out how to send beer to Venezuela)
Leak Down Test came out good
**Update: Here are a few videos highlighting the problem. Tried to capture AFR, Boost/VAC, and Fuel Pressure. Look at the boost gauge go bonkers. And yes...the autobahn rocks!!!
In 5th accelerating problem @ 1:13 and 1:36
In 5th accelerating
Pull in 3rd no issue
So far I've tried:
New Coil Packs
New O2s
Swapped Injectors
In 5th accelerating
