Acceptable values on Data Log?
Stigma
Florida
When i had a Buick G/N i used a software called Direct Scan to view and log data...
It gave me values for iac iat maf tps and knock....that these should be within...
Is there any info as too pertinent values that i can reference for 2011-2014 5.0 Mustangs?
I tried looking in the search bar prior to this thread but could not find anything...
I hope i listed this post in the right area?
Thanks
FIVE-OH
Whose your tuner? They should be checking your logs too.
Stigma
Florida
As stated in my signature i have a few tunes i use...and i don't want to say which tune because i don't want to come across as talking negative about the tuner i'm just curious... in 3rd gear i see -3.53 and 26.5 spark advance.... So i just wanted to know at what point is too much?
Stigma
Florida
I just found out that negative numbers are good,actually advancing the timing and + numbers are Negative-
So i am good after checking both logs from shell 93 v-power and then the data log after using 93 Sunoco i have 0 k/r-
Just wanted to update the thread-
