I still suspect vac issue. but here is some info on the code.
P2197
Lack of HO2S-21 Switch, Sensor Indicates Lean
Detailed Description
A heated oxygen sensor (HO2S) indicating lean at the end of a test is trying to correct for an over-rich condition. The test fails when the fuel control system no longer detects switching for a calibrated amount of time.
Possible causes :-
Electrical:
# Short to VPWR in the harness or HO2S.
# Water in the harness connector.
# Open/shorted HO2S circuit.
# Corrosion or poor mating terminals and wiring.
# Damaged HO2S.
# Damaged powertrain control module (PCM).
Fuel System:
# Excessive fuel pressure.
# Leaking/contaminated fuel injectors.
# Leaking fuel pressure regulator.
# Low fuel pressure or running out of fuel.
# Vapor recovery system.
Induction System:
# Air leaks after the mass air flow (MAF) sensor.
# Vacuum Leaks.
# PCV system.
# Improperly seated engine oil dipstick.
EGR System:
# Leaking gasket.
# Stuck EGR valve.
# Leaking diaphragm or EVR.
Base Engine:
# Oil overfill.
# Cam Timing.
# Cylinder compression.
# Exhaust leaks before or near the HO2S(s).
Possible causes :-
Electrical:
# Damaged HO2S.
Fuel System:
Induction System:
# Vacuum Leaks.
# PCV system.
EGR System:
# Leaking gasket.
# Stuck EGR valve.
Base Engine:
# Oil overfill.
# Cam Timing.
