looks small....
putting a cage in yours?
Good luck with the build. Thought I read your car was in the shop for transmission issues ?
3" upper pulley ?
Any fuel pump, injector, or exhaust mods ?
When you took the car to the track, what gear were you in @ the end of the 1/4 ?
Looking forward to updates..
Thought you had the 4.10's in, that's why I asked about what gear at the 1/4..
If you upgrade your TB, go for the FRPP mono-blade, made by the same co. who makes the twin 65mm. ( Accufab )
Cost is about the same, I think I gained 15 hp with the mono-blade over the twin 65mm.
Edit: My track does not like the fact I don't have a cage....
