Alternator Drag
SeaWeed
Billings, MT
Im in need of some guidence in regards of alternator 05 to 09 6g single phase 135amp vs the 2010 Denso alternator. My Car is still on oem motocraft at 146k miles. Im long overdue ( battery light occasionally flashes randomly.) An about 16 check engine dtcs Checked connections an battery is already newer 600cold crank Duracell. I also want to be able to run 1000rms amp an not have issues. An yes i already know of shaker500 an 1000 problems [ dumbshit maker wiring all amps to a 1ohm load svc sub]. I just wana be more informed Hioutput vs the redivised Denso
Let's debunk an internet myth here and now. The '05-'08 GT Motorcraft alternator is NOT a single phase unit. It's a three phase unit just like every other automotive alternator on the planet.
It sounds like you need to upgrade yours to a higher output unit. Therefore I suggest you go to the Department of Boost website and look at the upgraded Denso units they have on offer.
https://www.departmentofboost.com/product/bulletproof-denso-alternator/
