Battery in trunk. Grounded to welded in roll cage.......
That should be fine.
But I also at one time ran a seperate (1/0) ground cable direct from the battery to the engine block...... Made no change.
I've done the same test, no change.
Battery feeds directly to the BEC on the fuse block.
So the pos battery cable goes to the fuse block? The alternator cable goes to the fuse block? And the starter hot cable goes to the fuse block?
We have three cars set up like this. Works good.
Alternator is in stock location.
Had a powder coated alternator once but have the new OEM on it now.
It shouldn't have a ground issue then. You can test if it does real quick though. Just run some 2-4ga cable from the alternator case directly to a chassis ground and see if things get better. This is a long shot though, I wouldn't put money on it.
Thought the same thing earlier this year. Made a 3.5" pulley for the alternator to slow it down. Max RPM I believe the alternator is seeing now is 14K-15K.
To quote my buddy who own the alternator company when I asked him how fast a 6G could be spun:
"If it is spinning at all it's spinning too fast".
Obviously an exaggeration, but it does show what he thinks of the 6G design.
In theory you aren't spinning your alternator very fast. That said I have seen them come apart in just a few miles. They are time bombs. You may have gotten two junk ones in a row. My neighbor has a stone stock (well at least until last week) 08' GT and it has had 5 alternators put on under warranty.
That data log is with the engine at idle.
Now that is interesting. I'm going to need to think about that/ask some questions of my friend.
Have you done the voltage test at the alternator/battery that I outlined above? I would be interested in the exact numbers you are getting.
I'm sending you a PM right now.
