pcdrj
I purchased both the BMR and the CHE. The CHE were beefier and fit nicer. IMO they were better construction.
Well, I actually run drag radials on the street, so we'll see.Man, are you in for a BIG surprise when you get those bars paralell!! It'll feel like you have slicks on the back when you're pulling out of the driveway! Have fun!
I also think they would have to have some upward angle, otherwise the IC would be way out in front of the CG.so having the LCA's parallel is the optimum setting?
i thought they should point slightly upwards (up front) so the car would plant the rear wheels down harder
That's a good link too. And some of the angle change on my car may be due to running 28" tires also. I'll experiment with the angle/IC, and see what works best... but I suspect I'll end up somewhere slighty greater than 100% AS.Wow, ok, that surprises me, I always tought that stock it would at least be parallel to the ground, over time I expect a spring to sag and may be that is what happened here don't know 1/4 to 1/2" seem a lot...well
I found this link, and I better understand why some guys launch very hard but spin down further down the track (too much anti squat)
http://www.hardcore50.com/technical_articles/LaunchingPart1.htm
I know nothing about drag racing, but for my setup (hot street, occasional auto cross & drag strip) , I wiil try to aim for a 100% or less IC.
The steeda bracket will give you 1 more hole for trial and error testing, good thing you choosed it.
Have fun
I read in a thread that the bushings shuld be greased once a year...my car's a DD, is that frequency applicable, or should it happen more often? I only have a week on them (BMR rear sway bars)....and lubed them with silicin grease....That's what it's for, for the surface, to help you ummm, slide it in. You'll want to get a grease gun or your bushings will look like this soon.
Putting jackstands under the axle housing will keep the suspension loaded.it was a pain to install as i didn't have a platform lift to keep the suspension loaded..
It might... but then again it also might move the instant center too far back, which could hamper weight transfer. I just plan on experimenting at the track and see which position works best. Eventually, I'll get it dialed in right.anyway, now a day later, i'm starting to wonder whether i should try relocating the LCAs to the lowest point available on the bracket and see if that helps with the launch traction even more
how exactly does a grease gun look? does it have a flexible nozzle to reach through the tight areas like the front bushing of the LCA?
Don FYI I measure the height of the LCA bolts on my stock suspension (other than a BMR rear sway bar) with OEM wheels/tires, (measuring at the center of the bolt) and the rear bolt is 3/16" higher that the front....which would mean the straight line through those points and the straight line of the UCA probably intersect way in front of the car somewhere...if at all...
Exactly the same situation I had... the LCAs pointed down.
First of all, welcome to S197Forum!! Good to see you here!Don,
Mine were pointing down too after I lowered the car. Wheelhop was insane after putting on the KB so I went with this rpmoutlet setup:
http://rpmoutlet.com/05gtrear.htm
My LCAs are now parallel to the ground and wheel hop all but eliminated. A really good buy since the billet LCAs come with BMR relocation brackets (welded on), all for $200. Of course it's a crapshoot dealing with rpmoutlet, but they've always made things right by me.....eventually.
I already had BMR LCAs that I bought last year, so all I needed were the relo brackets. I bought the Steeda's because of the extra adjustment points they provide. They are welded on the car now... which I'll be picking up tomorrow afternoon. So, I'll get a chance to test them (and the new TC) on Friday at the track.
Glad to be here!
