I am looking at getting a set of anti-squat brackets (aka LCA relocation brackets). The two I am considering right now are CHE (
http://www.cheperformance.com/CartGenie/prodInfo.asp?pid=209&cid=15) or BMR (
http://bmrfabrication.com/2005MustangDRIVELINE.htm)... however I am open to other suggestions.
One thing I do like about the BMR bracket is that it has two position settings, whereas the CHE only has one. That will give me some additional adjustability for dialing in the suspension.
I'm looking for feedback from those of you who have installed these, with respect to quality, fit and finish, installation, durability, performance, etc. Any and all comments will be appreciated. TIA...
I've got the BMR pieces installed, and had no issues whatsoever with the installation. There have been reports of bad spacers being supplied (too long), but even that's an easy fix. The brackets installed simply and easily, with just a tap or two with the HANDLE of a hammer to get them in place, and the control arms slip in like butter with all the bolts loosened. If the upper mount bolt is torqued, it compresses the bracket JUST enough to make it a PITA to get the control arms to line up.
A couple of observations with respect to instant center and anti-squat. The upper hole in the BMR bracket is nigh-on perfect with a drop of around 1.75" in the rear, which is what I'm running. The lower mount point is EXTREMELY agressive, and may actually create too much anti-squat. In that configuration, the ride is abusively hard, and if you don't get enough weight transfer to the rear, the back will actually lift. Correct me if I'm wrong, but ideally, on launch, you don't want the rear end to do ANYTHING. As the front lifts, the weight transfers to the rear, and with exactly 100% anti-squat, ALL of that transferred weight is on the tires. All the rear does is rotate a degree or two, in sync with the front end rise. With less than 100% anti-squat, the rear end sags, and with more than 100%, the rear will rise.
With my car being set up for handling rather than pure traction, I'm running a 1.25" drop in front, a 1.75" drop in the rear, with heavy bars front and rear, and with the LCAs mounted in the top bracket hole, I'm just a shade away from paralell to the ground. With a 1" drop like you have (I think), you'll have a slight "up" angle on the LCAs, which will indeed shift the instant center towards the rear of the car, and increase your anti-squat.
I'm also considering moving to the Steeda brackets, but more for the finer adjustability in the "handling" range than because there is an issue with the BMR brackets. For the drag guys, I think it's a hard piece to beat. Right now, the BMR brackets are the lowest part of the chassis on the car, and for my purposes, the extra bracket length is wasted metal.
