I think I read they operate up to 3000 rpm or so, but after that they're innefective due to engine vibrations. Anyone got the specifics on this?
What he said... Stock tune uses them throughout the entire range. Stroking, boring, supercharging etc.. all have an impact on the knock sensors as they are essentially microphones.Stock in the S197, the knock sensors are used through the entire RPM range. You add a supercharger, change anything in the rotating assembly or anything like that and you will most likely change the knock signature....
get gas from another station and try 89 octane to see if it goes away
Your tuner can also adjust the how much timing is pulled due the knock sensors. Rather than turning them off, just set it up so it pulls 2 or 4 degrees instead of 10 or more, or what ever they are currently set at.
BTW, does anyone know what the timing curve is for a stock GT? How many degrees at each rpm point?
Thanks, interesting information.Unfortunately or fortunately depending on how you look at it, timing is not nearly that easy any more. Rather than a simple 2D table as in the past, there is a base spark table called the "Borderline Knock Table" that rather than a simple timing based on RPM is now a 3D timing based on RPM and load. This table is modified by at least 4 other tables like knock sensor, CHT, EGT and ACT. I can tell you under no load there is as high as 50* advance and under full load in the stock table there is a max of 17.5* @ 4,750 RPM and it goes down to 16* at 6,500 RPM. That would be max timing stock with no modification from any of the above listed tables. -Joe
BTW, to get the degree sign (º), press the ALT key and at the same time on the number-pad, enter 167.
That's useful information if only I could remembr it. Maybe I can write that down on my keyboard. -Joe
To help you there are a few sites out there (I have a sheet printed) and this site is likely the smallest amt. of info on any of them so it is quick to find help on it if you forget:
http://tlt.its.psu.edu/suggestions/international/accents/codealt.html#math
