- Joined
- Apr 5, 2007
- Posts
- 6,356
- Reaction score
- 58
I only had belt/tensioner issues on an auto with the vortech at 15+ psi. I haven't had any with the KB
what blower, what psi?
Somewhat off topic but.....
I was running an Innovators West 10% overdrive crank pulley with the Reichard Racing belt tensioner and 2.75" blower pulley. This setup produced 675rwhp @ 22psi on race gas. The first problem I had was with the RR tensioner pulley going bad. RR sent me a replacement pulley and I was back on the road. Then KB came out with their tensioner and I switched to that because I didn't like how close the RR tensioner was to the pcm. I also put in a Meziere electric wp (again) with a 5.5" V10 sized pulley for more belt wrap. The wp was tough to get on, we ended up having to remove the overdrive pulley to get at the bolts. About this time, we noticed the new KB tensioner was making noise and the belt was out of alignment. KB sent me a replacement, and while we were at it we removed the overdrive pulley and replaced it with an 8 rib pulley ($42 at Autozone) that's made for 1997 - 2000 5.4 engines. This is a 7" pulley, the overdrive pulley is 7.5". I was looking to lower the boost so this was a good place to start. Just for grins, we also swapped out the 2.75" blower pulley for a 3.25" pulley and put it on the dyno. The car now makes 600rwhp @ 15psi on 93 octane. So now the stars and my belt seem to be in alignmentbut I want a little more boost, at least 18-19psi. The 2.75" pulley is going back on today. If that puts us over 20psi, then I'll order up a 3" blower pulley. I just want to take advantage of the 2.6H KB which really begins to shine above 15psi. This BTW, is before we put on Adam's monster TB and ported intake. I'll keep y'all posted.
There are 2 issues with the design of the Reichard Racing tensioner when used on the 05+ cars.I just don't see how a damper would resolve this issue. I think I've stated this a few times before...when you let off the gas to shift, even the slightest blip, the crank, A/C, S/C etc. are all rotating at different rpm's. This is what's causing the belts to break or bending the tensioner then shreading the belt. This is the same reason that a strenghtened tensioner arm is not the solution, but just a bandaid. Thump (with a Reichard) has shown that as well as a few others, including myself (reinforced arm with 1/2" plate of aluminum welded).
The A/C is a potential solution b/c of any resistence etc. in the rotation of that A/C pulley. It just stinks that anyone would have to remove the damn A/C to resolve something that you would think the S/C companies would address.....especially being that they have MUCH more resources than all the end users!
Look at the GT 500,the blower has a seperate belt,isolated from the other pulleys.There is something to be said about that.
Oh gawd... when Ted reads this, he'll start babbling about the ProCharger having a separate belt, too.so do the 03/04 cobras
the only problem i see with it is if the snout gets longer, we might rip the snout off haha. theres a reason why on the Cobras and the GT500 the S/C belt is closer to engine and the accessories are father away. its to keep the snout length as short as possible. id rather bend a tensioner then snap a snout off a supercharger.
