Bud
Scaled the car again at it's full race weight. 3183lbs
With the ARB disconnected the corner weights were:
855 - 823
782 - 721
Put the ARB links back in and adjusted them while on the scales to get the weight showing on the rear the same for both sides and ended up with 762lbs on each rear tire. Problem is with the ARB adjusted to get the weight even in the rear the passenger side sits almost 1" higher than the driver's side.
When adjusting an ARB do you go for no preload and adjust from there or do you want to use it to even the weight out in the rear so each tire see's the same load?
Also I have to add 120lbs next year to be legal weight, thinking about putting some weight just behind the passenger seat until the car is the same side to side, then maybe the rest over the diff. Any suggestions on that?
855 - 823
782 - 721
