jcodestang
I have a 2011 with the factory 3.73 rear gear ratio in it. Over time the rear end has developed a howl at 60+mph and on deceleration after letting off the gas.
I'm pretty sure that the pinion bearing is loose, I know that the spec for a used pinion bearing preload is 8-14 in lbs. Does anyone have a spec for a fully assembled rear end? I have taken off the driveshaft and rear brakes.
When I put a torque wrench on the pinion nut and rotate everything the break away torque is 16-18 in lbs
I am trying to avoid taking out the gears if I don't have to.
Thanks
Thanks
