EGNARO
Orange Backwards
ok so my car is an 07 gt.
I've had it for close to 7 years(8 years maybe?)
for the past 6 years its been pretty much stock performance wise with the exception of some borla stinger mufflers, and a JLT CAI with a shitty bama tune.
recently installed a roush m90, pacesetter longtubes with hi flow H, and detroit rocker cams. got a tune from lund.
when i upload the new tune to the car I'm getting p2107 and a wrench light. and the car will not start.
starter engages, i have fuel pressure, ( at the rail at least), and the Throttle body flutters when i turn the key on
stock Throttle body and TPS, and i did clock it like you are supposed to. i also checked the voltage as per ford when its at a 45 degree angle. i also swapped to another stock throttle body i have from a different car. same result.
what else is there to check? is my pcm bad and just throwing out this bogus code because its fucked?
I've tried re uploading the tune and even had lund send the tune again with no change.
all fuses are good, been checked multiple times. all wiring to the throttle body and TPS sensor are good
