BBK Long Tube Header Hardware
SmokeOps
Recently picked up a cheap set of used BBK long-tube headers. I was wondering if anyone knows if anyone sells the hardware for it or what I can buy if I were to source it myself. I also bought a BBK catted X pipe for it, and I think there are the longer exhaust bolts for that too that I will not have, so if anyone knows where or which bolts I should buy for those, that would be greatly appreciated. I know that if you buy a new set, it comes with some hardware you have to modify. If there are some aftermarket bolts I can get that wouldn't need modifying, that would be preferred. Also, does anyone know if I can just use a stud that I cut to fit where BBK says I need to use the bolts?
Thank you
