Ruff idle after long tube header install
smpw
Kansas
Hello
Can't find anything on here so I thought I would ask
I just installed long tube headers on my 2014 gt 5.0 and was wondering if it's normal for the car to run ruff and die when coming to a stop the only codes I have are for the (IAT) and the (MAF)
I've checked all the wiring and fuses cleaned the MAF and looked for vacuum leaks but the issue is here I have 12v at the harness of the MAF
Just wondering if this is normal or should I replace the MAF
StockishS197
Houston
Have you updated your tune?
It has to be updated to increase the O2 transport delay, otherwise it will run rough, especially at idle/low exhaust velocity.
You dont need a tune for transport delay on a gen1 coyote.
Car has fault codes... Hmmmm, what should be the first step??
