bc coilovers
2012_Rs1
i have a 2012 rs1 with 20x9.5 rims wrapped in 275/35zr20 all the way around. I plan on installing a set of bc coilover on my car here soon is there anything else that needs to be installed at the same time to prevent scrubbing and help with the ride?
travelers
Eastern Pa
An adjustable panhard bar to keep the rear centered when you lower it. Also is the front upper mounts adjustable?
o2sys
NY/NJ
BCs come with camber plates so like travelers said adjustable Panhard bar would be the minimum.
2012_Rs1
Thanks yall, also any of yall had thr bc br coil overs with the swift springs on there 11-14 mustang? btw nice car travelers
Chriss_302
Socal
Honestly it all depends on what you plan on doing with the car.
Daily driver? I'll stick with a good set of springs, panhard bar and a good alignment, no need for coilovers if you DD, just my .02. :party52:
pass1over
I like it LOW
Trenton, FL
I've had a set of BRs on my car for about 3 years now, with the BC springs though, not the swifts. Panhard bar would be all you would need to put a BR kit in.
I put coilovers on my DD because I wanted to make the wheel gap exactly how I wanted it to be.
zorph01
Virginia
I've read that people have had a little troubling accessing the caster camber plate adjustments through the ST so you might need to open up the hole a bit. Can this be confirmed?
