Best spark plug gapping tool 3v
07supergt
I'm buying a new set of plugs for the car soon and need to gap them before installation as I haves. Saleen super shaker. Most likely going with the autolite ht0. The question that I have is about the gapping tools out there. I have bought and returned the jegs brand because it was not machined correctly, testier on a old plug and it was collapsing one side. There are two others that I have found. One from MMR and the other from steeda. Anyone have any experience to recommend either?
http://www.modularmotorsportsracing.com/prod_modular_engine_tools.htm
It's all the way at the bottom
Steeda
http://www.jegs.com/p/Steeda/Steeda-Spark-Plug-Gap-Tool/962908/10002/-1
BruceH
BBB Big Bore Boss 322
If you buy the frpp branded hto they will come gapped at .032". If you want an easy way to gap ht plugs without a tool it can be done.
All you need is a spark plug or other deep socket that will fully cover the top of the plug to protect it against getting damaged, a vice or c clamp, and a screwdriver, socket extension, or other suitable sized shank.
Put the plug in the socket. Put the socket with the plug into the vise or c clamp with the shank of a screwdriver on the ground strap. Close the vise until you have your desired gap. It works well, is easy, and most of the time you already have the parts laying around.
bw281
Would then frpp branded htos be the m-12405-3v0 set by any chance? I searched and couldn't find a gap rating from ford on them.
BruceH
IIRC they are the 3v0 plugs. FRPP doesn't list a gap. However, every set I've bought has been gapped to .032". It's even written on the box. Others have reported the same. Maybe they don't do it anymore? I haven't bought a set for over two years and now have the newer style heads.
bw281
So is it better to go with the HT0 or the FRPP??
I don't think one is better than the other. I chosen the frpp 0 degree plugs based on a good price I got on sale from Tasca. I think quality control would be more of an issue than performance for the likes of frpp, brisk, auto lite, NGK, etc. I would recommend price shopping as part of the decision.
07supergt
Well I ended up getting the HT0 from work for 70 bucks. They where already gapped to .035 so no need for the tool.
