Billet SHR window switch plates
doogie
SE WI
After pre-ordering these back in Feb. from Silverhorse Racing, they finally arrived about 2 weeks ago. As with all SHR products, the quality is just outstanding as these pieces are milled from a solid piece of aluminum and were well worth the wait! By getting in on the pre-order I not only capitalized on lower initial pricing, but also had the opportunity to get a set without the standard pinstripe (which is all you can order today). Mine have the anodized/satin finish, which matches the UIP interior very nicely.
The install took all of 10 min. as you basically remove the old switch plate, pop out the switch assembly and plate mounting clips, and reinstall them on the billet plates. The fit and finish is awesome... and looks so much better than the stock plastic plates (along with any of other "tape on" covers currently on the market).
