BMR Bushing install
JUSTA3V
Moar Throttle!
Queen Creek AZ
Is this normal?
Stock bushing sleeve is 85 mm vs BMR sleve at 81 mm
I want to make sure I have the right bushing before I cut my stock one out
slackinoff
East Texas
I just finished this. I used a prothane bushing. The design looks quite different. One tip though, take the inner sleeve out before you push the bushing in. Turned mine from impossible to hand push easy.
slackinoff
East Texas
I did not check that....Other than the upper controll arm being "frozen" in the up position and me have to rig up a ratchet strap system to pull it down, everything was fine in fitment.
R.M,
JUSTA3V
Moar Throttle!
Queen Creek AZ
Mr Lito. Put on your glasses.
The aftermarket bushing is shorter than the stocker. So no hammer needed.
I'm concerned about it being 4 mm shorter and requiring shims? Or it may be the wrong bushing all together.
2005Redfire6
Acworth, GA
The bushing looks a little wider but it should be ok since the UCA attaches to bolt sleeve deal which should be the same width as the stock.
2011/5.0
Iowa
Try measuring the edge of sleeve to the outside edge on the stocker and compare that to the step portion of the bmr,looks like you'll have a 4mm gap in center of sleeve, possibly for a grease zert?
Sent from my XT1585 using Tapatalk
JUSTA3V
Moar Throttle!
Queen Creek AZ
I did. Here. Let me do this again
BMR Sleeve
Stock sleeve
See? I have a 4mm difference. So in my mind. If I install this bushing I will have 4mm worth of play.
My question is do you think this is normal and ok? Can I make up the 4mmwhen I tighten the upper control arm to the bushing? Or is this going to cause a clunk??
Looking for people who have installed this item for help.
JEWC_Motorsports
S197 Junkie
Texas
I just measured my stock bushing and it is also 84mm. I would contact Kelly or Dylan at BMR.
05stroker
Never enough power guy!
Bullard Tx.
I would call BMR as well but if it's tourqed to the spec the UCA will conform.
BMR Tech 2
Kelly's Replacement Lackey
Tampa, FL
I'm going to look into this for you when I get into work tomorrow. I'm thinking that you ended up with either the wrong sleeve or one that wasn't made right. We'll get this taken care of for you!
BMR Tech 2
Tampa, FL
Ok, I just pulled a few off the shelf and checked them... Looks like you just got an improperly cut sleeve. Shoot me a PM with your shipping info, and I'll get a new sleeve headed your way.
JUSTA3V
Moar Throttle!
Queen Creek AZ
Thank you sir. When you have a minute. Could you post some pics of a properly assembled one so I can see the difference?
BMR Tech 2
Tampa, FL
JUSTA3V
Moar Throttle!
Queen Creek AZ
Thanks that's the difference. I have no gap between the bushings.
Also which is drivers side. I assume the non tapered bushing?
BMR Tech 2
Tampa, FL
Correct! You push the tapered end in though the drivers side, then push the drivers side piece though. How I have it assembled in the first picture, is how it should look once finished.
JUSTA3V
Moar Throttle!
Queen Creek AZ
Do you insert the removable bushing ends after the innear bushings are in place? Then press in the sleeve?
