Bolt or Stud Size for GT500 Spoiler
StageMe
Pasadena, MD
As the title says I need to know the bolt or stud size for the GT500 spoiler I just bought a used one and it did not come with the bolts. I would like to be able to put it on today. Thanks
tmcolegr
It's All About the Build
Central, FL
The GT 500 spoiler should have come with 4 studs. Nonetheless the size of the studs are 6mm x 1.0
StageMe
Pasadena, MD
Yeah I know it should of but it didnt...Im really not that worried about it because it was such a good deal. Thanks for the info I will run out and buy some today and get that thing on. Any good suggestions for removing old double sided 3M tape
tmcolegr
Central, FL
Let me offer some suggestions:
  • Trunk lid must be cool to the touch
  • Loosen but do not remove the 4 nuts holding the original spoiler in place
  • Take about a short length of fishing line (I prefer Power Pro stranded or braided - 20 lb. test available @ Walmart) and carefully use the line to saw through the existing 3M adhesive. You have to do this from all 4 sides as the fishing line will stop when it reaches the mounting studs.
  • Now remove the nuts and spoiler
  • Carefully use a heat gun to soften the remaining 3M adhesive
  • Follow up with VM&P Naptha (available @ Home Depot) to remove any remaining glue
Does your new spoiler have any adhesive on the mounting surfaces to prevent water leakage into the truck compartment?
StageMe
Pasadena, MD
Yeah the GT500 Spoiler has old 3M take on it that needs to be removed so I can clean it up and put some new on......
