boost gauge hose keeps popping off?
Error404
photographer
Culver City, CA
So, my boost gauge vacuum hose going into the intake manifold of my whipple sometimes pops off when I go WOT, since the boost was upped. I'm guessing the pressure is just to much for the rubber nipple that it goes into.
Any suggestions on a non-permanant way to keep it from popping off? My first thought was some sort of glue, but that might be a little more un-reversable than what I'd like. Maybe a ziptie, but it's an awful small diameter to zip tie, I may try it though.
Suggestions?
Miracle
"Shall not be infringed"
Clarksville, TN
They should make hose clamps that small... it's what I had to do to mine.
But is it a rubber vacuum line, or is it the tiny nylon hose that actually goes into the gauge itself? If it's the nylon hose, are you sure you put the coupler together correctly with the lock collar around the line?
fastregalwe2
Need more powa!
Virginia Beach, VA
put a dab of super glue on it and a small zip tie. The hose on the waste gate of my GN were popping off @ 25psi and that was the fix that worked for me
05mustang_TT_charged
Because Race Car!!
LSU Country
+1, small dab of super glue on white hose and stick it into rubber grommet, then put a 1/8" zip tie on grommet to "T" fitting
Kaldar142
Silver Spring, MD
yep, been doing this for a LONG time now with all my boosted cars.
also hairspray on the intercooler couplers :) heh
