buffing pads?
VTXFrank
Obama SUCKS!
Santa Rosa Beach, FL
10" pads? Hole-e-chit! I thought my G110v2 with 6" pads were a tad too big!
There's a thread by DKS in this area. It's the sticky at the top of this area.He gives a lot of great advice and websites to buy things from.
VTXFrank
Obama SUCKS!
I think it is. The larger the pad, the harder it is to control it, the more it fatigues you and the more work you have to do to get the product you're using to break down into the paint. It also tends to sling more as well. The larger the pads, typically the slower the speed you will want to use. If the recommended setting for medium is a 5 of 10 on your machine, you'll want to use a 3 or 4 because the larger the pad, the faster the outer edges of the pad are moving compared to the center. Unless you're using Griot's products like you are for now. They give recommended speeds on their products based on their buffer.
Did your machine come with a 10" backing pad? Can you swap to a different size backing pad? If so, I would shoot for a 4"-6" maximum pad diameter.
DKS
Wax on, Wax off.
VA/NC LINE
Rotary = Bigger pads = faster speeds at the edge= faster work
DA = Smaller pads = faster movement = faster work
Zexford
Somers Point, NJ
Quick dumb question, can you reuse pads? Can I wash them out or something? Would be annoying to keep buying these $10 pads every time I detail the car.
NastyStang113
Made in U.S.A.
Central Florida
Yes, just buy a pad per product. They can be cleaned whey they need it. Most products if you're using the right amount of product don't need to be cleaned every use.
