Bump Steer Kit with 15 inch Racestars
TheDarkPath
Houston, TX
Hello everyone,
I have searched and could not find anything about this. I run 15 inch Racestars at the drag strip and 18 inch wheels on the road. I read about people having clearance issues with some bump steer kits with 16 inch wheels. Would any of them work with the 15" Racestar wheels?
I was having major squeaks in my front suspension. I removed, cleaned, and regreased the a-arms and the squeaks are gone. While doing that, however, I found the stock tie rod ends looked very worn looking (maybe looks are deceiving). Car has been lowered for about 20,000 miles and the last time I had the suspension alignment done, I had a toe in issue that was mostly corrected but the alignment tech said a bump steer kit would help perfect the geometry.
I am also having the pop noises from the stock strut mounts so those will be replaced before my next alignment with either the GT500 mounts or MM CC plates/mount.
Suspension setup:
Tokico D-Spec Shocks/Struts
BMR Lowering Springs
BMR Non-Adj A-Arms
BMR Radiator Support/Swaybar Delete
BMR Camber Bolts
BMR Panhard Rod
BMR Rear LCAs
BMR Adj Rear UCA
RocketcarX
95% of my weight is fuel
Colorado
Run the 18x5 from Racestars and be done with it. The car will be much more stable without the sidewall that you have to run in a 15 inch wheel.
RocketcarX
Colorado
TheDarkPath
Houston, TX
Thank you RocketcarX! I like how that combo would still match and look good with the 15x8s out back.
thump_rrr
Montreal Qc,
Do you know if they will fit with Brembo front brakes or any other big brake kit?
Edit: Nevermind. I just realized that they are 15".
