Car won't stop revving, bouncing off rev limiter!!!
JoshK
Modder AKA Fuel
Nebraska
I took the car out tonight and went WOT. When I let off the gas pedal, it didn't come back up and the engine kept revving eventually bouncing off the rev limiter. After about a second I could feel the pedal pop back up and hit the bottom of my foot. This happened a couple of times while the car was being tuned. The tuner said that he had to update the software on my X3, reloaded the tune and then it didn't do it anymore. Can someone please help me with this, I really don't want to blow up my engine.
bullitt boy
NJ
Inspect the throttle body and make sure its not sticking open. Start with the simple stuff.After that get it back to your tuner.
3vs197
welcome to my world. take a look at the carpet/floor mat. i managed to wear a hole in my carpet where the pedal touched and the corner was getting stuck there. a quick trim of the pedal/carpet fixed that issue.
JoshK
Modder AKA Fuel
Nebraska
It acts almost like the pedal is sticking down, is there a way that that could happen?
JoshK
Modder AKA Fuel
Nebraska
Now that you mention that, my car has those big rubber walmart floor mats in it(were in there when I bought the car). I just went out to the car and pushed the pedal all the way to the floor and it got stuck under the floor mat. Took out the mat and threw it in the trash and now the pedal doesnt stick down. I will have to drive the car tomorrow and see if it happens again when the car is running. I would've been so pissed if I lost a motor because of a damn floor mat.
badgt06
Stratafortress
Waco, Tx
Sounds like your mustang thinks it's a Toyota? Lol. Check the simple stuff first (obviously floormats/carpet, petal connections, TB, then tune and other tricky mech stuff).
ramrod07gt
i too have had this happen a few times.. scares the crap out of you! good luck hope that fixed your issue
GrnBullitt08
Dale Jr
Northwest Indiana
If it continues to have this problem, inspect Throttle body and PCV valve line...or rubber hose to make sure eveything is good.
Its probabley just the floor mat playing tricks on you.
white05gt
Illinois
If the pedal is sticking down, it has nothing to do with any of the above mentioned except the floor mat since it is not a cable operated pedal.
GrnBullitt08
Dale Jr
Northwest Indiana
I had similar problems with my car reving and holding high RPMS.....solution was that i kept blowing the PCV tube off that goes from the valve cover to the manifold under boost.....
It was just a suggestion if the floor mat wasn't playing tricks on him....dont get your panties in a twist. :mad2:
JoshK
Modder AKA Fuel
Nebraska
Running breathers on my car so I am guessing it was just the floor mat(which is in the trash now). Going to do some more datalogging tomorrow so I will let you know what becomes of this.
white05gt
Illinois
Since when is stating the obvious getting my panties in a twist? He stated the pedal popped up :roflmao:
fdjizm
Drag Queen
NY/NJ
Sorry your car went all prius on you.
I don't think that has anything to do with your tune, your pedal is not physically linked to anything.
If it got stuck then it was the floor mat or something just siezed in the pedal assembly.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Anything related to Walmarts does the same thing to my wallet!!!! It redlines when I walk in the door!:helpme:
JoshK
Modder AKA Fuel
Nebraska
Took it for a drive this morning. Went wot and let off with no problems. Floor mats are evil!!!!
LOL, at the Toyota comments though.
Mach1Marauder
LARGE MEMBER
Phoenix, DFW or a trailer at the track
Stock floormats did that on my SuperDuty. There's a rubber stripe on the road in front of the shop when racing a SRT10 truck. I almost didn't get shut down before the street dead-ended into the interstate.
Thump thump thump back to the shop
