Cheap Spoiler Delete!
07stangcs
Undecided
Houston,TX
Ok well looking into buying a ducktail spoiler and decided to find my options b4 jumping in. Found Kris selling his ducktail in the classifieds and him having the SS Gen 1 ducktail(Factory holes not covered) i needed a way to cover holes without it getting to expensive. Thought " Oh this should be easy". Unbolt 4 bolts and replace with plugs and good to go.... WRONG! Me never unbolting my spoiler, not knowing some dumbass at FOMOCO decided 4 bolts wasnt enough to hold a barely semifunc wing. NOOOoooO they had to add gobs and gobs of SUPERMAN STRENGHT 3M tape. Needless to say it wasnt fun getting it off and on top of that, the shit sticks to just about anything as your workin your ass off to remove it. Having an 07(Made 09/2006) that shit was bonded on there hella good. Found good water tight plugs at Autozone for about 2 bucks. Heres a few pics of the "Easy:wtf:" cheap spoiler delete.
Removal of decklid made the work much easier(And a hell of alot cooler indoors)
This shit right here is CRAZY STUCK!
45 Min later! Almost done with one.
1 Down and 1 bastard to go(Goo gone is prolly bad for paint but hell nothing else worked.
Little soapy water got it cleaned up.
All done with plugs in.(resizing image made them look weird)
All done and back on the car.
Another view.
All i have to say is JUST CAUSE THEY INVENTED 3M DOESNT MEAN YOU GOTTA PUT THAT SHIT ON EVERYTHING.:yuck:
kleistang
Miami Florida
it looks better than i spected. gj
lol dude ur setup up is really close to mine haha even made almost the same power
Mustang30212
Columbus, Ga.
You can really see where the spoiler was in that last picture. Did you try to wax or buff that area out any at all?
Also....do you thinki it could be more noticable with the white paint?
RH
07stangcs
Undecided
Houston,TX
In the last pic you can see the Platnium turtle wax. Took awhile to buff it out but it matched pretty good. Gonna paint plugs to match in the morning. For a total of $1.98 for plugs and $4 dollars for "HP" code Duplicolor paint i think it will look good.
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
Since your car is white and you ripped that spoiler off without screwing up the paint, you should try filling those holes with epoxy, mask off the area and hit it with some touchup paint. I tried this and it will work, but it is difficult with a darker colored car.
GRAYPNY
Rich
NorCal - Chico
Man that antenna looks terrible on the trunk. I put my aftermarket antenna on the package tray and it works fine. That wasn't one of Ford's better ideas imo.
doogie
SE WI
3M adhesive remover is your friend when dealing with that crap!
I just pulled off my chin spoiler since I dinged it up and just some soaking with adhesive remover and a little elbow grease quickly removed all the 3M tape. Goo gone does help with the last little bit, but the remover really helps get the adhesive broke down.
alexthejew
Jewish and lovin it.
you know, i may just try this. the spoiler can always go back on.
Chicago, IL
"3M adhesive remover is your friend when dealing with that crap!"
That stuff is awesome, but it's not too good for your paint. Use sparingly. I don't really care about show quality paint myself, so I use it often. Just try to wipe it off quick as possible.
1Fast05Turbo
Flying Low
Valrico, FL
I use the 3M pinstripe removal tool. It is fast and will not damage the paint when used following the manufacturers instructions.
http://www.goferauto.com/3mstwh.html
alexthejew
thanks for this. i just took off mine.
i will clean it up and take more pictures in the morning.
