Clutch time
C-Liz-Go
Resident Realtor
Houston
Looking for a stocker clutch or one rated max of 550rwhp to replace mine which is officially toast at 197k miles.
Contact me directly if you can help. [email protected]
Thanks in advance, fellas.
Liz
bullitt boy
NJ
10 spline? Looking for a fly wheel too 8 hole or 6 hole. I have a used Ram HD power grip with about 11 k on it. Changed it out when we did the tranny. Clutch should work in a stock set up i believe but the fly wheel Ram Billet steel is an 8 bolt stock is 6 bolt. You can have the clutch for $50 + the ride.
C-Liz-Go
Resident Realtor
Houston
New RAM has been ordered and will be installed sometime this week, in addition to a new slave, struts, replace the rotors. Tires are next. Then maybe replacing the rear bumper.
Work in progress, it WILL be resurrected.
