These are fresh back from Comp. They would seep a little oil on the compressor side due to high oil pressure so Comp checked them and verified this. They machined new backing plates and were tested to 140 psi without an issue. Unfortunately though my new motor combo will not allow me to use a T4 turbine housing due to clearance issues. I would also need to go to a smaller compressor housing which in all would cost me over 1000. The better option is to part with these and find something smaller physically or go to a big single. I'm asking $1800 shipped for both and that includes paypal fees.
Specs:
62mm Billet compressor wheel
62mm turbine wheel
4 inch inlet (anti surge)/ 2 1/2 outlet
.58 divided T4 turbine housing (you can use this with an open T4 flange)
Oil and water triple ball bearing center sections
Thanks Mike
Specs:
62mm turbine wheel
Thanks Mike
