Firefighter46
I have a running and driving 2013 3.7L base, with a 6R80 transmission. I also have a complete, running 2014 Coyote and mated manual transmission with a complete body harness. My question revolves around whether or not I'll need to swap the entire wiring harness or will the body harness from the V6 car work with the Coyote and manual trans?
I figured I'd need a different engine harness (I assume it plugs into the body harness) and manual transmission harness (I have the pedal assy, clock spring, and gauge pod as well from the donor Coyote car).
Did the body harnesses between the different engine options differ?
I'm compiling the differences between the two builds before I start the swap process.
Any help will be appreciated.
