Corbeau Harness Install
remainvayne
I'm trying to install my 4-point Corbeau bolt-in harnesses into the circled location under my rear seat, but I can't get these freaking bolts off! Any ideas/suggestions?
icebox
toronto
can you show some more pics of that install. I was think about getting one
thanks
danbev07
Road Course Junkie
Orange County, CA
That's where I mounted mine, but it's very close to not being safe.
lol it's either safe or not safe - there's no gray-area.
i was always under the impression that you mount the shoulder straps higher than your shoulders?
Kuro!
Banned
Austin, TX
Your height and seat will make it safe or not safe. So yes, I would consider it a gray area.
Kuro!
Banned
Austin, TX
If you mount incorrectly you run the risk of using the force of your body against you and compressing your spin in an accident.
remainvayne
Yeah, I know its not technically safe/correct but it is what it is.
I got the driver's side bolts off but I broke 3 torx bits on the 2 passenger side bolts. Kuro, any suggestions on how to get those bolts out easier without snapping any more bits?
remainvayne
work out more :beer:
Yeah no kidding. I was worrying about stripping the bolts, but I guess I'm lucky my torx bits were cheap and just snapped before I ruined the bolts. The driver's side came off easily, but the passenger side isn't budging.
Locite breaks down with heat. Just do it.
OK, since I haven't done that before, do I heat around the bolt like on the body of the car?
Kuro!
Banned
Austin, TX
Heat the bolt up. 6" back or so and just heat it up for a few seconds, should come out fairly easily.
