blue streak
Anybody have it or seen it? http://www.lastcallracing.com/cxr-cfs-40-1000-t.html
would love to see the watts link in action.
Sorry to revive an older thread...I am very interested in the Cortex setup...can anyone comment on the validity of JAJ's comment above?A couple of things to keep in mind about the design of this kit:
First, there don't appear to be flags on the struts to connect the front sway bar. Perhaps they're made for one side only and the flags are underneath, but it does look weird in the picture.
Second, the coil-over setup in the rear is going to move the vehicle's weight from the frame to the sheet metal wheelwell, which is not nearly as strong. This is usually only done on cars with a roll cage that reinforces the wheelwell so the shock and spring assembly doesn't punch a hole in it.
I haven't seen any rear coil-over set ups "punch a hole" in the steel in that area, however...
1. Most well-done cage set ups do reinforce this shock mount area, and I strongly suspect it is to strengthen this area to receive the additional loads they'll see with a coil-over.
2. I have directly witnessed buckling in the rear quarters of an S197 for no apparent reason...beyond the fact it had rear coil-overs and was tracked hard (thus the reason for my suspicion in #1).
I wouldn't be surprised if this is a non-issue for cars that are only street driven. But then again, if that's your use, why bother with this level of mod? =)
Best,
-j
I seem to remember that shock loads are *way* higher than spring loads--I wouldn't be too concerned with the rear strut area...
Actually, it's the other way around - spring loads dwarf the shock loads. The spring holds up the weight of the car; all the damper does is slow down how fast it's moving relative to the axle. The static spring load, even without any spring compression, is roughly double the highest dynamic load from a racing damper. Add extra load from spring compression over bumps to the dynamic damper load on the upper shock mount and the total load will easily be four or five times normal.
