JesseW.
since its designed to fit a 315 rear wheel i do not think the coilover mounts where the shock mounts. it would make a lot more since if it mounted in where the spring is on the axle and body and has a few bolts and a top plate mount you have to drill for to hold it in place on the body and another mount you weld to the axle spring perch. anyone have any install instructions?
::edit:: just found a pic. looks like they have a bolt in upper mount that would go where the spring is and a weld on bracket for the axle .
