max2000jp
Took about an hour to figure it out. I was having the same issues as lostsoul.
Saw voltage through the VMP wire so I knew that it was wired correctly, so that meant a bad X-cal or something with LiveLink. I played around with LL for about 30 minutes and nothing would work. Finally, I noticed that that male end on the VMP cable didn't plug all the way into the x-cal. I took a razor blade and took about 1/4" of the plastic ring off the cable and that enabled it to insert ALL the way into the X-cal. Plug it in and fired up the car, BINGO. It's working well so far. I need to permanantly wire the cable into the Autometer Wideband since I just have them twisted together.
Lostsoul, try trimming the cable and see if it works!!!
