Well I firgured Id just throw this out there incase anyone is the furture needs help trying to fix this probelm....
I tried to change over my stock TB electronics to a L&M 62mm TB. As some of you may know, theres a spring on the inside of the larger housing. That spring needs to be "Clocked" or wound up counter clockwise to keep the TB blades closed at idle of when off the throttle. If you do not do this you will throw 2 DTC's....
P2104
Throttle Actuator ctrl system - forced idle
P2111
Throttle Actuator ctrl system - stuck open
I did some searching and found this thread that helped alot...
http://www.s197forum.com/forum/showthread.php?t=62904
Now here is where I wanted to throw some more info out because the solution in that thread will not work with the stock GT 55mm TB spring.....
You only need to "Clock" the spring 1 full rotation, counter clockwise. The above thread is dealing with a GT500 TB spring which must be different since they needed to clocked it 3 times.... Anymore tension you will throw...
P2112
Throttle Actuator crt system- stuck closed
Meening the actuator cant operate due to too much tension on the blades... Hope this helps anyone with this prob in the furture
P2104
P2111
P2112
