Hollowdweller
- Joined
- Jul 10, 2018
- Posts
- 414
- Reaction score
- 52
Been having some high reving issues since the rebuild. Tuner is aware and trying to help with the issue but I dont really want to hassle him with it if it’s not a tuning issue. According to the tuner everything I’m sending him looks good but is sending different files to help try to detect the problem thru data logging.
I’ve only driven the car MAYBE 75miles since rebuild…can’t keep her running long enough to go to far lol!! During driving the car will idle up to 3500 and stay there until I come to a complete stop, then hang a few secs and drop to 900rpm. This happens 2-3 times during a 5 mile trip thru town. Yesterday I didn’t get 20ft outta the driveway and it idled up. I pull over & stopped, wait a few secs and it drops to 500rpm (900 normally) and the wrench light pops up. When I turn around to head home the car has no throttle response. It feels like it’s flooding out every time I try to give it gas. Car stays at 500rpm, sounds like it’s gonna die but doesn’t. Pull codes and get P2104 & P2111 (P0579 cruise control related I think)
I added a BBK throttle body during rebuild. Voltage test was .171 stock and is now .190….could that voltage difference be the issue? Research on the codes said the TB motor could be getting stuck..blades spring back good IMO. Thought about trying to get another rotation on the spring, maybe needs more pressure?
I dunno….looking for tests to run, things to check, sensors to replace, could .019 voltage difference cause this? Vacuum leaks?….how do I actually check those? I mean I’ve tightened and redone them several times now
I’ve deleted all the EGR stuff off, tuner is aware
