Disabling Auto Lights??
v8venom
Face
New Orleans, LA
I have an 07 and when I unlock my car with the keyless entry the headlights come on, is there any way I can disable this?? Thanks
Mike
AlloyGT
Lurker
Highlands Ranch
From Page 79 of your owner's manual....
Enabling/disabling the perimeter lighting feature
Your vehicle comes with the perimeter lighting feature enabled. You may
enable/disable this feature by having your vehicle serviced by your
authorized dealer.
You may also perform the following power door lock sequence to
enable/disable the perimeter lamps feature. All vehicle doors must be
closed before beginning the procedure. You must complete Steps 1–3
within 30 seconds, or the procedure will have to be repeated.
1. Turn the ignition to the 3 (ON) position, then press the control
three times.
2. Turn the ignition to the 1 (OFF) position, then press the control
three times.
3. Turn the ignition to the 3 (ON) position; the horn will chirp to
indicate the driver configuration mode has been activated.
Activating or deactivating the perimeter lighting once in program mode is
accomplished by:
pressing the trim panel power door unlock control ( ) twice within
five seconds.
It didn't paste correctly, but every time it says "press control" in the above instructions, it's talking about the unlock button on your remote.
Hope this helps.
v8venom
Face
New Orleans, LA
Thanks Alloy, I dont have my manual because it was stolen when my car was broken into so I appreciate you taking the time to write that up for me. Thanks a lot.
Mike
mwilkes
cheesewhiz
Houston, Tx
does this work on a 2006 mustang as well? i can't find that cars user manual
v8venom
Face
New Orleans, LA
I just tried it, and it didn't work. It says disabling the perimeter lighting, is that what I am talking about? When my headlights turn on when I use my keyless entry??
