Does the GT500 and 5.0 GT Share the same front o2 sensor?
Seer
I see on tousleys site two different prices, but does anyone know if they are the same sensor?
Fullboogie
King of the Ski - OG Jr.
Houston
On the older models (like my '07 GT500), yes. Not sure about newer ones, and I see you have a '12.
Seer
Yep, I'm seeing that. Trying to track down the root cause of this P2195 and P2197 issue i am having.
It's been happening after I've installed headers.
01yellerCobra
San Diego, CA
Do the newer cars need to have the transport delay lengthened?
Misspelling brought to you by Tapatalk
Seer
No, i told it is a learned function. Car ran fine for a few hundred miles after the headers.
AnotherS197GT
Serial Valve Dropper
USA
Don't they have the same PCM and engine from 07-12? Did it have to be programmed in the older models?
Seer
no, they switched to an aluminum block in 2011, it uses the same pcm as the 5.0 (copperhead), and also uses widebands and knock sensors like the 5.0 does.
Just different part numbers it looks like.
