Drag Racing in the Heat? hooking problem, tire pressure?
xtweakerx
Get SOME!
Palm Beach, FL
ok just raced my first bracket with in the dead heat, summer is bout to begin and get worse. I was having problems hooking all day, some passes better than others but all Crap compared to my hookage before this blistering hot day.
I normally run 17 psi in my M&H Drag Radials and I've gotten a best of 1.790 I tried the same psi and i couldnt manage better than 1.98 i tried lower it, worse, tried upping it worse.?!
any tips for when the track gets super hot, it was about 89 outside and sunny. should i run the same psi? When its hot out do u up the pressure or lower it? :hi:
xtweakerx
Get SOME!
Palm Beach, FL
damn i think i just figured it out, i was always doing big burnouts in the fall and i did the same thing in this hot day and i most likely just need a small burnout when the track is hot.. urgh.
MickeySaleen
Barricade
From what I understand, it should be easier to hook up on a hot track...rubber softens in heat allowing better traction...
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Not true. Once the track temps get too hot, the track gets greasy and it's as bad as a cold track.
US-1
Banned
The ShadowLands
What track?
Were there a bunch of street tire cars running?
What is your pinion angle?
What springs are on the car?
Were you lining up in the same spots?
What was the track prep like?
xtweakerx
Get SOME!
Palm Beach, FL
What track? - Palm Beach International Raceway
Were there a bunch of street tire cars running? Mixed but mostly drag radial.
What is your pinion angle? Stock
What springs are on the car? Stock
Were you lining up in the same spots? Yes, i tried both lanes
What was the track prep like? No Clue, prob not great lets say average at best.
:helpme:
US-1
Banned
The ShadowLands
:helpme:
Yup....about what I figured. No suspension work, manual transmission, inexperienced driver, mediocre track prep. Not trying to bash you here but you just need more seat time and possibly some suspension work to make the car consistent.
