2005 4.6 GT Ford Racing CAI
Miker
USA
I got an SCT X4 recently and running the canned 91 octane tune for a stock intake really did change the car. It runs smoother, pulls harder throughout the curve and even sounds different.
Not being able to leave well enough alone I found a Ford Racing intake that is the same as the one that came stock on the Bullitts. The only intake choice in the canned 91 octane tune that comes close in maf size is the C&L street that I believe is an 83mm maf size. The Ford Racing I believe is an 85mm. In the GlassTop09 post above you can see that's exactly what he did.
I would rather not get a custom tune and am wondering what the effects would be with a 2mm difference in maf size would be?
Would I be able to see if there was an issue in the short term fuel trim in the data logging screen?
So I got the intake and Installed it. Loaded the tune for 91 with the C&L intake and took it for a spin. It was much hotter out than when I ran it with the stock airbox. It ran good but did not seem to react as quick to the throttle in the lower rpms as the 91 tune with the stock intake. I have Data logs for each SCT X4 configuration I ran. Stock tune, SCT 87 octane tune with stock intake, SCT 91 octane tune with stock intake, and 91 octane tune with the C&L intake. Again the C&L gets closest to the Ford Racing CAI in Maf size. C&L is an 83 maf and the Ford Racing is listed as an 85 maf but there are some questions there.
My seat of the pants dyno says reinstall the stock airbox. The data logs for all 4 configurations are fairly consistent but I truly don't know how to read them.
One thing that was obvious was the IAT temps. It was a little over a 100 degrees out and the highest the Ford Racing CAI posted was 114. The stock airbox on a 90 degree day posted a high of 134.
Another thing that is obvious is how much better the Ford Racing intake looks. Plus everything about it screams OEM quality.
Probably going to contact Lito and get a tune for it that will have the correct maf size. Hopefully it will run the best it has so far.
AHaze
Edmonton, AB
85 mm vs. 83 mm is a 4.9% increase in cross sectional area. I would expect the car would initially run approximately that same 4.9% leaner than what the tune calls for and then adjust back in the LTFT, at least when running in closed loop. I'm not sure how well these ECUs transfer that into open loop which is where it's most important that you aren't running lean.
Miker
USA
Thank you for the reply. It felt lean so I took it back off. Waiting now for the tune from Lito before running it.
It is a well thought out intake. Pulls all it's air from the front lip of the hood and is completely sealed off from the engine bay heat as well as possible. Probably loses a little to the intakes with the straighter intake tract but the oem fit and finish is what I like.
StockishS197
Houston
I would also clean or replace that filter if you want maximum flow…looks a little over due.
For a relatively stock car, the FR CAI is a nice piece. If you ever start going with bigger mods, there are other intakes with larger MAF housings that may benefit though probably not huge gains.
Miker
USA
Not sure why but Ford filters for this were originally dark gray. This is one of those filters. But it is a bit dirty. I have a new Motorcraft filter coming for it. They changed them from the dark gray to yellow. K&N also makes a filter that fits this but I want to stay with a dry paper filter instead of an oiled one.
Miker
USA
Here is the new filter on an original Bullitt intake. The Ford Racing is not painted on these and there are two huge resonators that hang below the intake tube.
Miker
USA
Got the first tune from Lito. What a pleasant experience. Contacted him on Sunday about noon with all the details and he emailed the first tune at 6 pm! That's some service! Now sending him a 5 minute idling data log to start any revisions. Already like the results. Pulls hard and all but gone is the delay to compression braking when lifting off the throttle. And got the new filter. You can actually hear the intake now. The other was pretty much done.
Miker
USA
Had to send a 25 minute data log to Lito with different speeds, different loads, some idling, and 1 pull from 2000 rpm to 6000 rpm in 3rd gear. Found a stretch of road and tempted fate and got away with it although I did lift at 5945 rpms so I sort of chickened out I guess.
Just received the second tune and it seems to pull even harder.
If anyone is on the fence about having a custom tune done to their 3V Mustang GT through Lito, jump off that fence and do it! I can't recommend him enough.
An unexpected side benefit is about a 20% increase in mpg even with all the pulls for the data logs. That makes the difference in cost from 87 to 91 octane a wash.
GriffX
Rural Germany
I would be interested in your log file. I have the same engine and intake (except I have the greenish cotton fiber filter).
JC SSP
FL
Does it make sense to archive these for future use? Including stock parameters?
whitmanink
denver pa
i also have a lito tune for my " all but full bolt on ",mutha thumper, phaser limiter req,cams ,,i cannot say enough good things about him
GlassTop09
Farmington, NM
Just saying thanks for posting all this......................
FYI.............the grey one is the Ford MC part# FA1891 filter (higher performance) that were also sold thru Ford Performance (I used to get\run these very same Bullitt air filters thru American Muscle until FP discontinued them some 4-5 yrs back....). The one you're running (now myself as well.......) is the Ford OEM Bullitt replacement part# FA1895 filter which uses the same paper element filtering media as used in all other Ford OEM designed air filters.
I initially replaced the discontinued MC FA1891 w\ the K&N E-1997 Bullitt replacement air filter & ran it until I recently saw a YouTube video that Lake Speed Jr put out w\ a well-known & recognized industry air filter manufacturer (Donaldson)......then I started searching recently & found the Ford OEM FA1895 Bullitt replacement filter on Rock Auto, so I bought 1 & installed it to then test..........found this filter made a BIG difference on air mass flow resolution thru the MAF.........cleaned this up quite a bit while showing no total air mass flow rate loss thru it when I compared it to the K&N.
Engine idles better, accelerates better, runs much smoother & when it was all said & done......I was able to pull approx 2% out of my base calibrated MAF transfer & set it dead on Lambda 1.0 across the board (w\ EVAP isolated so it won't skew the actual base MAF calibration......I found this is not being taught to do in tuning training materials when doing a base MAF calibration thru an OEM Ford ECU, but it should be........I figured this out myself thru datalogging the EVAP PIDs & seeing this system operate in tandem w\ the O2 sensors STFT & LTFT data & TPS data recorded in real time from a cold start thruout to engine shutdown after a full drive cycle period......WB O2 sensors won't fix this either......only bake the air mass\fueling errors from EVAP into the base MAF calibration the same as a NB O2 sensor will since all EVAP flow enters IM post MAF & TB thus SD is also affected......unless the EVAP system is isolated from the IM while initially calibrating a MAF & SD.......) & still not lose any total air mass flow rate or engine performance........this was how far off my base MAF transfer curve actually was due to the resolution loss thru the MAF that the K&N filter had caused (the MAF was reading more air mass flow than was actually passing thru it over 2/3 of the full TPS range due to excessive air oscillations hitting the MAF hot wire......due to the filter media design of the K&N air filter........more prominent during lower air mass flow rates.....). Filtering quality wasn't much of an issue (my oil analysis results were taken while I had the K&N air filters in service which backed up K&N claims concerning air filtering quality as none exceeded the silicon count thresholds thus were in "spec".......when the filters were properly cleaned & reoiled......) but the MAF resolution difference is an issue IMHO as this has a bearing on MPG & emissions as well, not just performance.
I'll be running this same Ford OEM Bullitt replacement air filter myself exclusively going forward.
In closing, you made a good choice to not go w\ a K&N E-1997 air filter.........
whitmanink
denver pa
i have a jlt intake ,
lito said my maf was kinda skewed , and im wondering if this is a reason why?
because ever sinvce i put on the cai , my idle was never %100 stable
GriffX
Rural Germany
The gray/green filter was an oiled fiber type and can be cleaned like the K&N. The K&N filter oil should have UV dye in it so that you can control the equal distribution, sadly not.
GlassTop09
Farmington, NM
Also posted for those so interested............
If you're asking me..................the answer is yes, for more than just the air filter itself.......also due to the MAF section size. This 105-110 mm MAF section\tube is just too large w\ the OEM MAF sensor slot being located too far away from center of MAF section piping & too close to the MAF section sidewall to be accurate at low RPM air mass flow rates (air boundary layer is turbulent air due to flowing friction off walls & can influence air contact to MAF hot wire thru MAF slot.....), thus will excessively slow the airspeed velocity thru the MAF sensor slot at low RPMs thus the air will not make as smooth, clean & consistent contact to the MAF hot wire thus can skew the 5v MAF reference output signal voltage from the MAF sensor to the ECU & cause similar resolution issues as these reusable cone air filters (due to the MAF sensor being located so close to these filters, it is imperative that the filter media provide some type of air flow lamination\straightening to clean up air turbulence prior air entry into the MAF section & especially thru the MAF sensor slot to access the hot wire.........this is why the OEM's use smaller MAF section sizing that locates this MAF sensor slot opening as close to the center of the MAF section tube as possible to keep it away from any air boundry layer turbulence occurring off the MAF section walls but also to maintain the airflow velocity thru the MAF section above a minimum required speed that will ensure good, clean & consistent air contact w\ the MAF hot wire element to eliminate voltage fluctuations that can cause the 5v reference signal voltage output from the MAF sensor to become erratic\unstable (thus the term resolution......)......throws off any calibrated MAF transfer function during calibration & afterwards which can\will throw off fueling......this can\will get worse if any tuners also intentionally disable MAF Adaption (race car thinking here....) in the tune calibration as well while using 1 of these CAIs.........they don't look good if your car is always randomly going into Limp Mode due to erratic MAF\SD airmass calcs that trigger excessive TQ errors thru IPC..........
But yours could also be due to a small vacuum leak around the MAF mounting flange (common w\ these ABS plastic tubes.......) or around the coupler at the TB that won't show up w\o the use of a smoke leak detector...........if you haven't already done this to eliminate this as a possibility.
But this statement of mine is a controversial topic for those who swear by these CAI's, much like the air surrounding CMCV's or 62 mm TB's.............regardless of any actual airmass flow data in existence that can potentially disprove the often-given reasonings for what has been established as "truths" concerning these components using WOT peak HP\TQ outputs off dyno sheet data alone........... This is 1 of these topics where that, just because someone made it "work" doesn't mean it is working correctly........just good enough to get by.
Individual choice is a good thing............as long as it is kept in that realm. When these choices are being touted as universal truths w\o any creditable evidence (actual air mass flow\resolution data to correlate any shown WOT peak dyno HP\TQ numbers.......not just peak WOT dyno numbers alone....), I've found that it all needs to be taken w\ a grain of salt. There is plenty of provided evidence out there across YouTube & other venues that can be used to both prove AND disprove the validity of the JLT 3 CAI claims. The only creditable evidence I've seen & noted around all this concerning this 3V is coming from Ford.........none of it provides any creditability towards JLT itself, outside of the general use of a cone filter. Ford has provided evidence to support using a cone filter vs a panel filter w\ this engine to optimize airflow thruput (aka the Ford-built 08-09 Bullitt CAI due to increased total filter surface area w\ the cone filter over the OEM stock panel filter......) ........just not a reusable 1 (too hard to maintain smooth airflow resolution thru MAF at lower RPM's thru a reuseable filter media.........dedicated race car OTOH, not an issue......) & definitely not 1 the size of the JLT 3 (just pure overkill & seems to be somewhat problematic at low engine RPM's concerning MAF resolution stability........).
This is why I initially chose to go w\ the Ford OEM 08-09 Bullitt CAI (actual 83 mm ID MAF section.......I physically measured mine at the time I installed it as it was reported to be 85 mm MAF......found this to be wrong.....the 2010 Ford OEM 4.6L Mustang CAI MAF section IS 85 mm ID......also physically measured it as I have 1.....intend to upgrade to it at some point in future.....) to upgrade over the stock OEM GT 80mm CAI but I was using the FP FA1891 air filters (grey media) w\ a dust sock until they were discontinued, then I went to the K&N E-1997 air filters until recently as I posted prior.........now I know for certain that this K&N E-1997 Bullitt replacement filter is not necessary or needed.....proven by actual MAF air flow data that immediately showed itself as soon as I had changed the filters out & installed the Ford OEM Bullitt FA 1895 replacement filter w\ a dust sock over it (the dust sock use was proven at the dyno to not be a restriction some 4+ yrs ago.......they make excellent "pre-filters" that can prolong a paper cone air filter's usable life........) thru a datalog & O2 sensor feedback correction, then made a WOT run to check the top end flow which showed itself to not be restricted in any way vs the K&N, then rechecked after making the noted corrections to my calibrated FR Hot Rod Cam MAF transfer function in my car's tune calibration thru another datalog that repeated all recorded prior thus proved the K&N air filter claims of improved airflow thus engine performance vs an OEM air filter to be false.........thru my 184K+mi engine at the least, but the much improved low RPM performance (hot idle quality, off idle & low RPM acceleration response, overall smoothness, cold start performance, etc from more accurate air mass calcs--both MAF & SD--thus more accurate fueling calcs thus more accurate O2 sensor feedback corrections......thru an 83mm MAF section......all items that cannot be shown thru a WOT-recorded dyno peak HP\TQ sheet.......doesn't make it not to be true as this can be demo'ed thru before\after tuning software datalog acquisition data........) was too obvious to ignore.
This aspect of doing your own tuning is where it can pay out dividends.............provided you put in the necessary time & effort to learn then properly vet established teachings\truths to either prove them valid or prove them false so in the end you aren't beholden to them or misled by any person touting them.
Just to put this out here, during my prior employment pre-retirement, I also--at 1 time--was a fully trained\certified F3 Measurement Tech (electronic gas measurement) for Phillips Petroleum Co before the merger w\ Conoco back in 2003.......so I do know a thing or 2 concerning air\gas measurement & the sciences surrounding it. The main reasoning why gas meter tubes are internally honed & polished while equipped w\ inlet straightening vanes is to reduce the boundry layer buildup from gasses flowing in contact w\ the inner pipe walls at high velocities as well as maintain a true inner ID size across the meter pipe length thus increases gas measurement calculation accuracy thru the orifice plate ID size in the center of the meter pipe & are sized according to the amount of expected volume flow output then resized as volume outputs change......meaning larger OR smaller as required........to retain measurement accuracy.
A slot type MAF sensor follows\emulates these gas measurement flowing principles within a CAI..........so larger just to be larger w\o actual creditable air mass flow numbers\MAF resolution stability to prove it is not better. Marketing 101.............we've all been pulled in by it at some point...........along w\ some level of peer pressure\influence.
With some items\components, your eyes can indeed lie to you if not bolstered by some understanding\knowledge of the sciences that are used to quantify the designs\sizing's that you see\are looking at......................
Any MAF section size >85mm is pure overkill (small enough to maintain good resolution thru the MAF section at low RPMs but large enough to not be a restriction at WOT...........when calculating ideal air mass flow thru a stock NA 4.6L V8 at 6,500 RPM's, a 83mm MAF section size is more than enough at these ideal WOT flows while providing very good MAF resolution stability at low RPM's w\ the proper air filter media being used.....) & isn't really providing any real benefit w\ a NA 4.6L 3V vs an Air Raid, C&L Street\Race or Roush CAI with or without the no tune required MAF insert installed or Ford OEM 08-09 Bullitt 83mm CAI--all within the margin of error thus is a wash........even w\ a cammed NA stroker, strokers make the usage odds seem better due to higher airmass flow thruput potential vs a stock block but not necessarily true just because.......mostly visual aesthetics & perceived performance improvements. Where these JLT 3 CAIs will truly shine (same also goes for all the CAI's I've mentioned prior......) is during consistent full WOT service, much in the same vein as a typical 62mm TB when viewed CFM flow-wise..........like a dedicated drag car or road course track car on courses that have long straights where the car can actually make full use of WOT speeds......think higher airspeed velocities that will "correct" the air resolution wash thru the larger MAF section...........but generally not so useful\beneficial otherwise from 1 vs the other.......from a specific CFM airflow POV perspective.......the deciding factor then is always the low RPM MAF resolution stability performance......larger MAF sizing will always be the loser here........where it counts the most.........fact.
But to each their own..........................FWIW.
GriffX
Rural Germany
What is the maximum air flow you can get in g/sec ?
GlassTop09
Farmington, NM
Calc'd from using the OEM Spanish Oak ECU stock 4.6L NA cyl air mass # in tune cal @ .00155 lbs per cyl (correlates to the earlier SAE J607 density reference model.........otherwise known as STD correction...........most load bearing dynos are using the later SAE J1349 vers 4 2004 density reference model otherwise known as "SAE" correction........FYI........), this comes out to 40.3 lbs\min @ ideal 100% VE @ 6,500 RPMs (Ford calls VE "air load".......) which converts to 304.66 gms\sec metric air mass at same ideal 100% VE.......at SAE J607 reference model, of course.
Now if you want to get even more nerdy............if using E10 cert fuel (std in US these days.......), the air mass numbers given will need to be reduced by approx 4%.........due to E10 fuel is carrying the 4% of oxygen in the fuel thus the MAF won't see it, but the O2 sensors will pick it up.........
This is why a lot of 1st gen S197 ECUs still using the old fuel stoich AFR of 14.64 (std for E0 cert fuel) w\ the current E10 fuel will show STFT\LTFT corrections at least +3.5% thru +4.5%.......that is, if the fuel injectors\injector data is accurate, MAF calibration is accurate & the injector variability is around 2% or less.......otherwise you can expect to be in the +5% thru +8% (or more depending on injector variability....) normally, thus the old +10% threshold.
Also, a reason why IMHO, all 1st gen S197's (05-10) should legally have the fuel stoich AFR setting corrected in tune cals to the current E10 fuel cert CoC'd by the EPA @ 14.08 to correct all this.......otherwise folks that are unaware may be chasing essentially false "vaccum leaks"...........
Just for kicks..........
GriffX
Rural Germany
305 g/s is around 366 PS ~ 360 HP. Air mass in g/s x 1,2 is approximately PS for NA and mild supercharged engines
What are your modifications? CAI + exhaust manifold and cam?
