Just a warning, flicking your wot switch as your in the middle of a pass is probably not the smartest thing to do. I did as you did and tried it on an empty street, and it's not so bad racing from a roll. But at the track taking your eyes off what your doing to fumble for a switch- not cool,don't forget there is another car in that lane next to you. You could try a momentary switch if you don't use the window switch. I'm sure they make them on the shifter ball still or on the wheel But It's so much safer with a window switch and theres a few out there too.Good luck, patience on the first few runs don't even worry about the car next to you let him leave first your et doesn't start till you do. Check your slip improve 1 step at a time
