bolivianpimp
I purchased a Powerhouse driveshaft from a forum group buy about 1 month ago. This weekend we were replacing the clutch and DS at the same time. When we went to install the driveshaft, we noticed that the flanges did not match to what the instructions (and pictures) noted. Flanges have machined fit design to fit snug with the rear end and transmission. The front of the shaft is designated with the black dust boot, while the back is smooth. Well, “front” flange which contains the dust boot fit the rear end and vice versa. With great disappointment, We reassembled the stock shaft since we did not want to install it backwards.
Today, I called Powerhouse and told them about this issue. They simply told me to install it backwards and that there would be no effect what so ever. When I questioned why and that if it was designed to go a certain way with the dustboot in the front then I did not want to install it contrary to original design, they replied that “it has happened before” and that they just installed it backwards. The front side of the shaft seems like it’s a bit heavier than the rear, or it might just be perception. Would mounting the shaft backwards negatively affect performance? Have you ever heard/seem the shaft assembled backwards? What would you do in this situation?
