TotoGT06
Finally gave and wanted more obnoxious sound. Went with Summit Racing pipes and Badlandz dual electric cutouts. Very easy to install the electronics, the piping takes a bit of skill especially if you want it welded in like I did it. Took about 3 hours between just measuring, cutting, aligning, re-aligning, more aligning, and then finally welding and putting on the car. The electronics come with a pre wired rocker switch and more than enough wiring to reach where you want the switch
The summit cutouts go from a 2.5 to 3" size pipe and slipped right over the pacesetter pipes. The electric cutouts are meant for a 3" pipe
Still need to take a video but it sounds so sweet having the headers open.
The only thing thats changed from these pictures is the passenger cutout I turned around so the motor is pointing like the other side so i dont keep bottoming out on it
