Ryan D
A couple folks asked for an update on fitment when I got around to putting on my pacesetter off road X from Summit. Got in on this afternoon, fitment was perfect. Removing the factory catted H, not so fun, but the new pipe fits perfect. I will warn you, the bung on for the passenger side front o2 sensor is just slightly lower than factory, and the sensor lead is JUST long enough if you unsnap the connection from the holder to give it another 1/2 inch of room. Welded in a bung on the vertical part of the driver side for my wideband, and cut the rear O2’s loose just past the plug so the car side connection stays clean in the case I should ever want to run rear o2 sensors again. Only issue I had is a tiny exhaust leak at the butt joint clamp between the x and the exhaust pipe on the passenger side. I put a couple more ugga duggas on the cordless impact and it seems to have solved it. If it returns, I’ll probably put one round of exhaust repair tape around the joint and then slip the clamp back over that. Sounds like it should now, if I get the feeling it’s a little too much at times, I’ll put a set of flowmasters or something on and put electric cutouts ahead of the X. Plenty of room now. Was pointless to do them before since you had to put them after the cats, wouldn’t have sounded any different than it already sounded with the cats and MBRP axle back with no mufflers. Just barely ran it long enough in the shop to start getting a little whiff of grape fuel additive scent. Will put a few miles on it Sunday and see how she goes.
