are those resistors on the front of both heads grounded securely ?
They appear to be.
Can anyone point me in the direction of something that shows all the grounds so I can check them all?
Did u mess with any engine ground cables/straps?
Will you be getting your 475 back from the shop???? lol
Fuck... Problem is still there. Checking SJB next.
Damn. What all did you do before it started to act up? Shitty deal is you have done a bunch of stuff and if something screwed up well after the fact it may be a bitch to figure out.
Electrical problems suck GLFTSO. Keep us posted
Yeah that's what I'm stuck with. The shop says the only thing they can come up with is the alternator is going bad. They've looked at everything else.Hope you fix your problem. I'm having similiar problems after adding few electrical things, hids , wideband, shift light , boost gauge. Installed PA alternator still getting dimming lights and random check charging system light. Been doing it for almost 3 months , brand new battery and everything. Let me know what fixes it !! I'm going to try upgrading my big 3 , and double checking some of my hid wiring.
You sure its not the fuse box assembly? Sometimes when water gets in there its known to cause all sorts of crazy problems like the ones you are experiencing. I had a similar issue on a towncar where water came in on the passenger side and hit the fuse box.
I had almost the same thing happen. When driving on the highway my battery gauge would spike, I would slow it down and it would go back to normal. I had the PA alternator and when I sent it back they said everything tested fine but they replaced a few parts anyways. Haven't had a problem since.
