08Spdemon
alright guys im stumped, fan quit workin about a week ago so i started readin up on it here, so ive been doin some diagnosing today and this is where im at:
underneath fuse box is good, all fuse in pass. side junction box and underhood box are good, i have the new style resister and its good, all connections are fine, now the fan will work fine as long as i remove the high side relay, but as soon as i plug it back in something shorts and the fan stops workin, now remove the high side shut it off and start it again and the fan works again? now the weird part is when everythings workin(with the high side removed), if i check the resister for voltage on both sides of it im getting full whatever 13.XX volts? im lost i just want it working the way its supposed to work, thanks
-Will
-Will
