Fender Flared 05-09
DRock
Been working on a project. Really wanted something that followed the lines of the car and took styling ques from LTMW and rocket bunny. Should be in paint by next week or early the next.
that's a lot of flare!!
what's the flare material?
Wes06
trying to fit some 345+ under the rear? :D
DRock
The flare material will be offered in Carbon fiber, and fiberglass.
The front flares are 1.5in wide per side and the rears are about 2.5in wider per side.
345s? Pshhhhhhh I should easily be able to fit 14in wide wheels :)
Wes06
Alllll the rubber
well notice i put a "+" in there, so easily above 345 :p
Wes06
did someone say wide tires?
hah
LS1EATINPONY
The Banker
So did you use foam blocks and lay down shaping foam over them? Then go back and bondo over them to get a smooth finish? I assume thats your method and youre making plugs and molds off of them
edit...
Whats the target price point on these for the consumer?
LS1EATINPONY
The Banker
Now someone just needs to do this for 10-14 models and we will be gucci
