GallopingFord
I'm Cam - Mr. Indecisive
Trufiber will be doing 2010-14 next... so I've heard.
The flare material will be offered in Carbon fiber, and fiberglass.
The front flares are 1.5in wide per side and the rears are about 2.5in wider per side.
345s? Pshhhhhhh I should easily be able to fit 14in wide wheels![]()
If you don't mind me asking, what material are you using to construct the flares with? It looks like you are putting a layer of bondo on top of something but is it like foam that you sculpt the form with?
unless you mean what's shown in the pics above?
Well, I think they start the process with a car that has a functioning engine.... sorry you don't qualify.
I'm just trying to figure out the process so you can put flares on that minivan you were telling me about.
So did you use foam blocks and lay down shaping foam over them? Then go back and bondo over them to get a smooth finish? I assume thats your method and youre making plugs and molds off of them
edit...
Whats the target price point on these for the consumer?
