no new personal best, but learning occurred
Northern VA Mustang Club track rental at Mason Dixon dragway. This was my first time out with skinny fronts (15" weld rts with 28" M/T ET fronts)
ran a couple of 12.5's with 1.6x 60's (car 5 in the pic below), and while this doesn't best my quickest run last year at MIR, it does best my runs at Mason-Dixon last year:
I think it's fair to compare the numbers at this track to see the improvement with the 15" skinnies:
per recommendation from stkjock, I used a paint pen to mark my rim and tire to see if there was any tire/rim movement - it slipped 1/8"
I mounted my gopro to my panhard bar so I could watch for tire slip; here's a look at a 1.65 sixty foot run slowed down 8x (I painted a 3" wide white stripe on the inside sidewall):
setup for these runs:
- cj springs
- strange single adj struts set to full loose
- strange single adj shocks +3 clicks from full loose
- UCA in upper hole
- LCA in middle hole on bmr relo bracket
- 4500 rpm launch
- 26x11.50-17LT M/T et street bias ply rear tires, 15psi cold
- full interior in place, gutted trunk
- 302 rwhp
I hope to see a similar drop in times the next time I hit MIR...
Code:
Mason Dixon
date 9/2013 4/2014
60' 1.777 -> 1.654
330' 5.186 -> 5.080
660' 8.067 -> 7.945
MPH 85.39 -> 85.86
1000' 10.557 -> 10.420
1/4 12.660 -> 12.517
MPH 107.25 -> 108.12
- cj springs
- UCA in upper hole
- 4500 rpm launch
- 302 rwhp
